NI TestStand
Log name of sequence files
I`m using a custom made user interface for teststand based on Full-Featured user interface.
I want to have a simple logfile of all te sequence files that I opened and closed.
I want to have this because sometimes a sequence fails after it is run after another sequence file.
to troubleshoot this issue i want the logfile.
I was wondering where is the best place to add the code?
I alreade made the same for the logged in user. In this case I placed the code in the FrontEndCallbacks.seq (LoginLogout)
(1,310 Views)
You could register for the ApplicationMgr events SequenceFileOpened and SequenceFileClosed and write to the logfile in the event callbacks.
https://www.ni.com/docs/de-DE/bundle/teststand/page/tsuiref/reftopics/applicationmgr_sequencefileope...
Hope this helps.
(1,291 Views)
