NI TestStand
Logging LabVIEW Enum output in Teststand report
I'm working with LabVIEW VIs in TestStand. I am allocating labVIEW enum output to the one custom enum created in teststand. but, all good but I am unable to log the enum name of selected enum value. Would it be possible?
Could someone how to do it?
chandrakanth
(1,493 Views)
Check this: https://forums.ni.com/t5/NI-TestStand/GetValString-quot-quot-PropOption-CoerceFromEnum-is-not-workin...
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,430 Views)
Hello Chandu29,
The default TestStand schemas only log the numeric values for Enumeration data types in the PROP_RESULT and PROP_BINARY tables.
For more depth information please review this article: Logging Enumerations as Strings - TestStand Help - National Instruments (ni.com)
Best Regards.
(1,375 Views)
