NI TestStand
Logging Step results to different fields in adatabase
Hi guys, would be great if you can help me out on this one:
Imagine if I have 3 string test steps within a sequence, and I want to log the result of each of these steps in a different field (coulmn), what should I do?
The main difficulty here is how to access the result of the steps individually, i.e, what parameter are they hidden under?
I have been accessing the parameter: "Logging.StepResult.String", but this gives me result from all three steps at once, and I can only store the 3 results as different record in the same column.
Thanks in advance!
(2,904 Views)
Hi jack@nz,
Are you using custom database steps in your sequence or process model to pull this information into the database or are you going to Configure»Database Options?  If you are doing the first method, could you send a screenshot of your sequence or the sequence file itself?  If you are doing the second option, are you customizing a schema, and if so, which one?
Cheers,
Kelly
Cheers,
Kelly R.
(2,881 Views)
