NI TestStand
Logging a string as the 2nd return value from a VI
I have a VI that returns a Boolean pass/fail which maps into step.result.passfail.  I return another hex value from the same VI that only needs to be logged on the datasheet, but has no pass/fail status. It comes back via a telnet connection as a string. If I convert it to a number I can use the null type adapter and call it a numeric limit test with a comparison type of none and it will get logged on the data sheet without any pass fail consequences. It would be simpler just to pass back the string and have it logged. In fact this is a general case, there may be  many times I just want something returned from a VI to be logged on the data sheet without any checking. What testStand tool/object/gizmo could one use?
jvh
(3,802 Views)
Tool/object/gizmo to use is an Action Step
Action Step
The Action step calls code modules that do not perform tests but, instead, perform actions necessary for testing, such as initializing an instrument. By default, Action steps do not pass or fail. The step type does not modify the step status. Thus, the status for an Action step is Done or Error unless the code module specifically sets another status for the step or the step calls a subsequence that fails.
You can use the TestStand - Evaluate.vi code module template to create a VI that includes a ReportText indicator.
(3,797 Views)
Action Step
OK, thanks. Where would I find this VI?
Just looked at some legacy code here. Seems like text was reported up via Step.Result.ReportText
(3,782 Views)
I don't know if your 'data sheet' is a custom report, but for the default report you can add parameter values to the report by using Step Settings>>Properties>>Additional Results>>Parameters.
In the next version of TestStand you will be able to the same thing by clicking a "log" checkbox next to a parameter.
(3,780 Views)
<TestStand Public Directory>\AdapterSupport\LabVIEW\TestStand - Evaluate.vi
Our group has been using LabVIEW/TestStand since 5.0/1.0 days and many of our legacy code/sequences still use the Test Data cluster. This is a typedef found in
vi.lib\AddOns\TestStand\_TSLegacy.llb\LabVIEW Test - Test Data.ctl
(3,777 Views)
What James said is probably your best option. To clarify:
1) use a pass/fail step for your boolean.
2) use the additional results setting on the step to log the parameter you wish to show in the report.
Hope this helps,
-Doug
(3,747 Views)
