NI TestStand
Logging data in calterm through TestStand
HI,
  I am using Calterm III & TestStand Tool.
As we do data logging in Calterm III maually which will store the data logs in Excel file, i want to get the same result through the TestStand .
So the step data monitoring in TestStand will help me or is there any another step in TestStand to get data logs of any parameter in Calterm II screen for perticular time duration?
(3,159 Views)
You need to better explain how you're using Calterm and TestStand together. TestStand as the primary test executive should be calling the secondary application and passing parameters/results back and forth with that application. Are you using some sort of API to have TestStand call a Calterm .dll or something of that nature?
CTA, CLA, MTFBWY
(3,146 Views)
