NI TestStand
Login into Teststand with Message Popup
I want to Login into TS with Message Popup. I tried to overwrite FrontEndCalback.seq like this:
But TS return an error:
What is wrong ??
(2,634 Views)
You are setting a user object equal to a string.  That doesn't make sense.
You need to acquire the user from the Users.ini file or create a new user and assign it to CurrentUser.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,611 Views)
I got thinking about it and here is some code to help you out.
Create a Local variable that is an Object Reference.  Then the following will log in your user:
Locals.NewUser = RunState.Engine.NewUser(Nothing),
Locals.NewUser.AsUser.FullName = RunState.PreviousStep.Result.Response,
RunState.Engine.CurrentUser = Locals.NewUser
If you want the user to do anything you'll have to add their privileges.
jigg
CTA, CLA
testeract.com
(2,599 Views)
Thank you ! But how can I add privilegies other way than using TS User Manager?
(2,581 Views)
