NI TestStand
Lookup String in TestStand-Set Property Value.vi
If I use Pass/Fail test type in a test sequence, what is the lookup string I should use in my Labview program for Set Property Value.vi. For instance, Step.Result.string will be used if a String test type being used in a test sequence. How about Pass/Fail test?
Thanks for your reply.
(3,109 Views)
the lookup string will be "Step.Result.PassFail" .
Regards
Ray Farmer
Regards
Ray Farmer
(3,093 Views)
