NI TestStand
Loop while expression shared in multiple execution of the same sequence
Hi everyone,
I'm using a custom Model derived from the sequentialModel (that's a requirement).
I need to run the same sequenceFile in a parrallel mode. My  sequence contains only a step with a custom loop, if I change programmaticaly the LoopWhileExpression in one thread, it also changes all the other thread running the same sequence, how can I prevent that ?
Is there any way to change the LooWhileExpression in one thread without an impact on the others ?
Thank you !
(2,578 Views)
Accepted by topic author romainvannier
If anyone is interested, I found a solution :
When setting the loop expressions of a step in the process model, I was giving them a static value every sequences shared.
I solved it by using expression using Locals tha way each sequences could have a different loop condition.
(2,477 Views)
