NI TestStand
Lost Connection Error to MySQL Database After First Run
TestStand: 2025 Q3 64-bit.
MySQL: 8.0.44 (Docker)
MySQL ODBC Connector: 9.5 (64-bit)
Schema: Built in MySQL Insert (NI)
- Tried unchecking "Share Data Link Between Executions"
- Database explorer works fine, and displays results from first runs
- Test connection works fine
- The first run works fine and logs fine, when I go to test the second UUT in the TestUUTs standard model, it fails with:
An error occurred calling 'LogResults' in 'ITSDBLog' of 'zNI TestStand Database Logging'
An error occurred executing a statement.
Schema: MySQL Insert (NI)
Statement: UUT_RESULT.
Description: [MySQL][ODBC 9.5(w) Driver][mysqld-8.0.44]Lost connection to MySQL server during query
Number: -2147467259
NativeError: 2013
SQLState: 08S01
Reported by: Microsoft OLE DB Provider for ODBC Drivers
Source: TSDBLog
There isn't any errors in my docker logs for mysql.
Message 1 of 1
(408 Views)
