02-20-2006 06:09 AM
02-20-2006 07:32 AM
@TSreedhar wrote:
Hi,I am facing a strange problem:I am trying to call the "MainSequence Callback.seq" file from the "SequentialModel.seq". For this I am trying to right click and Open sequence. But, I am getting an error message popup: "Cannot open the sequence call module file. The module sequence file path is specified by an expression that is evaluated only at the run-time". Can I get some literature related to this.Thanks and Regards,Sreedhar.
02-28-2006 11:48 AM
Hi Ray,
I learn something new with you all the time, buddy!
@Ray Farmer wrote:
With your sequence file loaded and the sequence MainSequence is the active window, you can execute either the MainSequence in your sequence file without a process model or with a process model. If you call it with a process model you would use the ProcessModel entry point either Single Pass or Test UUTs.
I didn't realize that you could execute the MainSequence without a process model. Is that what happens when you select "Run MainSequence" from the "Execute" menu?
JLV (aka. "theOtheray" )
02-28-2006 01:55 PM
02-28-2006 03:07 PM
Yes...
That is what we're discovering..
We're taking the advanced TS training with Santiago. Learning lots of tricks that may lead us away from CVI.. 😉
... now I can start having more fun with TS 😄
and having more opportunities to send you stars.. 😉
Ray (aka JLV)
03-01-2006 01:16 PM
03-02-2006 06:53 AM - edited 03-02-2006 06:53 AM
welll...
hummm...
I may be asking as many questions as providing answers... 😉
both at least a bit of both..
WOW.. I didn't realize the full capabilities of TestStand. Impressive...
But I won't change my nick to JoeTS... 😄
- Ray -
( It may get confusing with 2 Ray's in this forum 😉 )
Message Edited by JoeLabView on 03-02-2006 07:57 AM
