NI TestStand
MainSequenceResults not completed on ReportResult in threaded subsequence
I am using Record Result properties in order to retrieve some informations in the TestReport that is feed by MainSequenceResults container.
It works well even in subsequence until I declare this subsequence as 'threaded subsequence'.
Have you got an idea why MainSequenceResults don't have informations in this case.
I have seen the following link but potentially I launch N threaded subsequence from loop for. In order to wait I am using Wait for all Rendez vous "tag all thread launched"
Do I have to continue to use this method and insert wait for thread as link explain at the end of calling sequence.
(4,497 Views)
First of all, your terminology does not match the terminology used in TestStand. What is a "MainSequenceResults"?
You already provided the link explaining why the subsequence does not pass its local ResultList to the caller in case you configured the sequence call to be "New Thread".
But i doubt that you did take a look into the Community Example linked in the bottom of that KB....
Two remarks:
- A Rendezvous is the wrong type of step for this. Use "Wait" as the example shows.
- Be careful that there is a huge difference in the setting "New Thread" vs. "New Execution" in the sequence call. "New Execution" will not work as you expect.
Norbert
Norbert
Expert: Geometry
(4,467 Views)
Ok I forgot RendezVous.
So if I do multiple call of same threaded method in a loop, the solution explained in the link does not match.
My actual code
Create RendezVous(foo)
For      NThreadedLaunch
           call     mySubSequence                         NewThread
EndFor
Wait For All (foo)
For      NThreadedLaunch
           Wait             Thread(mySubSequence
EndFor
(4,464 Views)
My actual code
For      NThreadedLaunch
EndFor
Wait For All (foo)
For      NThreadedLaunch
EndFor
Perhaps what you want is:
For Loop
     Call sequence in a new thread
End
For Loop
     Wait for previously called thread
End
If so, you can do something like this:
1) Create a local variable that is an array of Object References to store the thread references. For Example: Locals.myThreads. Before your sequence call loop, do something like SetNumElements(Locals.myThreads, Locals.numThreadsToCreate)
2) In the advanced settings panel for the sequence call step use an expression like the following for the "Store an Object Reference to the Thread" setting:
Locals.myThreads[Locals.myLoopIndex]
3) For the wait step, use the "Specify by Object Reference to the Thread" option and specify an expression like the following:
Hope this helps,
-Doug
(4,446 Views)
