NI TestStand
Maintaining station global for multiple project
I am having multiple TestStand project on my pc with different station global's and My Types, Every time i need to copy/paste station global and myTypes to TestStand directory. Is there any way to override engine call back with TestStand workspace, so that both these files get copied to TestStand directory while opening the workspace. and also when i closed the the workspace it should copied to other directory so that i can used it later.
I tried with SequenceFileLoad and SequenceFileUnload for my main sequence but whenever i reopen the file, station global get updated. I want it to get update only once when i open the workspace.
Thanks in Advance.
Best Regards
Sumit Memane
CLAD, CTD
(2,497 Views)
1. Unless these variables are accessed by outside sequence files, it sound like you really should be using File Global Variables.  Then the two projects do not step on each other.
2. You could just make a sequence that loads the information and run only that sequence when you open the project.  You could also make a SequenceFileLoad sequence callback that loads the variables.
(2,492 Views)
