The values will show up in the report. Make sure that the following is true:
1) You are using a TS 2.0 process model, and not a custom version of your own.
2) The Report Option setting called "Include Measurements" is enabled.
If these are true, do the following debug:
1) Verify that the step result is showing up in the report, but not the measurements.
2) After you edit the step, look at the flags for the Step.Result.Measurement array property and verify that the IncludeInReport flag is set.
3) Then look at Step.Result.Measurement[0].Data and verify that the IsMeasurement flag is set.
Note: To look at flag values for a specified property, open the Properties dialog box for it. Then click on the Advanced button to view the flag values.
Scott Richardson
Scott Richardson
https://testeract.com
