07-15-2009 02:52 AM
i have a testplan and checked the memory for teststand and labview after each run.
After load: LabView 50MB
TestStand 110MB
After 1. Run: LabView 70MB
TestStand 120MB
After 2. Run: LabView 70MB
TestStand 126MB
After 3. Run: LabView 70MB
TestStand 125MB
After 15min break: LabView 70MB
TestStand 140MB
As we can see Labview ist always constant after the first run and all VIs are loaded into memory.
The interesting part are the last numbers. There i made a 15min delay (just did nothing with the computer after the third run) but the memory was 15MB higher. Any ideas why?
Why grabs Teststand memory when there is nothing running?
07-20-2009 04:05 AM
Hi OnlyOne,
what versions of TestStand and LabVIEW are you using?
Can you also see the memory leak when you run a standard example, e.g. computer mother board test demo?
07-20-2009 05:42 AM
Its Labview 8.5 and TS4.1.
The testsystem is at a customer-place so i cant test it.
07-20-2009 09:38 AM
maybe this KB helps with the memory leak, but I don't think that the phenomena described there would create such large memory leaks.
http://digital.ni.com/public.nsf/allkb/2210EDE67847514986256FA5000282D3
Other than that I couldn't find any out of the box answer to your question. We can only try to exclude several influences and find the root of this problem this way. Maybe you can guide your customer through one of the examples.
