NI TestStand
Message PopUp Maximum Button
Hi Guys.
I'm using the Message PopUp to select diferent options, but I need to put more than 6 Options.
The Message PopUp have 6 maximum, it is any way to increase the number of buttons into a message PopUp (more than 6)?
Message 1 of 12
(8,577 Views)
You may customize the MessageBox Steptype to add more buttons. The source code is available for you to change at the location:   Components\StepTypes\MsgBox
Message 2 of 12
(8,557 Views)
Add button in the message pop up will satisfy your question..
I tried with 2 earlier in my project... but this should work for 6 buttons also
Message 3 of 12
(8,483 Views)
There is no problem for 1~6 buttons, but I need to add more than 6...
Message 4 of 12
(8,448 Views)
Then add them. As already mentioned, the source code for the existing message box is available. Use that or create your own with whatever programming language you want.
Message 5 of 12
(8,441 Views)
I´m also trying to have 7 button in the popup menu.
  • I open the "msgbox.prj" with my editor but I really dont know what i need to change or include in it.
  • I also open the "msgbox.h" and I´ve included (#define MAX_NUMBER_BUTTONS   7) but nothing changes in my program.
Could you please help me with this?
Thanks so much in advance!!
Message 6 of 12
(7,294 Views)
You need CVI/LabWindows development Software to program the MessageBox source code. You can add n number of buttons and program it to do the specific task you plan.
Message 7 of 12
(7,288 Views)
I cannt do it without that??
thanks for your help!!
Message 8 of 12
(7,286 Views)
Other options will be create your custom message box using LabVIEW or C# and call it from TestStand.
Ravi
Message 9 of 12
(7,260 Views)
Hi Luis,
If you can live with having the options split over several Message Popups, ie. not all displayed at the same time, then there is a way of doing this with the 'out-of-the-box' Message Popup.
I've created an example sequence that pulls the options into the Message Popup from an array (it'll work for any number of elements) and displays them in the popup.
If the option they want is not in the first five, they can click for 'MORE >>'...
...and the popup will update with more options from the array!
This is all contained in one Message Popup step and acheived through custom looping and pre-expressions.
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
Message 10 of 12
(7,235 Views)
