NI TestStand
Message Popup dialog box - "Value invalid or out of range"
Hi
From time to time I get an error when trying to display Message Popup dialog boxes. The error appears sporadically and always disappears when I restart TestStand. This happens for all Message Popup dialog boxex (TS standard box).
The error is "Value invalid or out of range". I get no clues as to why this occurs.
Any ideas?
TestStand 2010 SP1 running on Windows 7 64bit.
(4,993 Views)
Can you provide the sequence containing that step?
Without seeing the parameters, its quite hard to give you some hints where to look....
Norbert
Norbert
Expert: Geometry
(4,990 Views)
