NI TestStand
Message Popup
Hello, I would like to know if its possible to set the default focus in a "Message Popup" so I don't have to click it with the mouse, everytime that it appears.
Thanks in advance!!
(116 Views)
Accepted by topic author Elfernro
I’ve found it now. In case it helps anyone else, you can simply do it under Button Options by selecting Active Control on the button where you want the cursor to be.
(109 Views)
