NI TestStand
Message popup when sequence loaded
Total newbie to TestStand, first post Smiley Frustrated
I've noticed that the act of opening some of the TestStand example sequences will cause a popup message to display describing what the example is about. I'm trying to figure out where that message originates. It is not in the sequence steps.
Thanks!
Jim Haas
(5,863 Views)
Accepted by topic author JHaas
Welcome to the message boards, Jim,
It will show up in a callback.  When you have the example sequence open, you will notice that there are some sequences in the sequence pane that are a different color (sort of purple).  You add that callback to your sequence, and edit it similarly to the way the example was edited.
GSinMN
(5,856 Views)
Here's a great document on callbacks and how to use them as GSinMN pointed out.  There are different types of callbacks in TestStand.  The purplish ones are Engine Callbacks.
http://www.ni.com/white-paper/6605/en/#toc3
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,844 Views)
Thankyou!
Jim Haas
(5,839 Views)
