NI TestStand
Method to Single pass
Hi all...
Is there any method to single pass the current sequence...
I'm building a customized operator interface... I want to use a method to single pass... and i don want to use connectcommand.commandkind_execution_entry_point_set...
Thank you...
Message 1 of 10
(4,330 Views)
The Method you what is Engine.NewExecution(). Check out the Reference Help and look at existing code in the supplied OI.
By the way, the connectcommand.commandkind_execution_entry_point_set will invoke the NewExecution method.
There are a number of posted examples for using the New Execution method on the forum.
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 10
(4,325 Views)
Can the engine object be accessed from application manager or sequence file manager or execution view manager control...?
If so how...?
Message 3 of 10
(4,323 Views)
i.e I am creating the operator interface only from the three active X controls...(application manager,sequence file view manager, execution manager) so
Message 4 of 10
(4,317 Views)
i.e I am creating the operator interface only from the three active X controls...(application manager,sequence file view manager, execution manager) so from
Message 5 of 10
(4,316 Views)
Message Edited by lordsathish on 08-05-2008 01:16 AM
Message 6 of 10
(4,315 Views)
Message Edited by lordsathish on 08-05-2008 01:12 AM
Message 7 of 10
(4,315 Views)
Message Edited by lordsathish on 08-05-2008 01:09 AM
Message 8 of 10
(4,315 Views)
Message Edited by lordsathish on 08-05-2008 01:10 AM
Message 9 of 10
(4,314 Views)
Application Manager has a method called GetEngine() which you can call to get a reference to the engine.
Kristen
Message 10 of 10
(4,270 Views)
