NI TestStand
Missing File: TestStand - Set TestStand Application Window.vi
While opening a file "Simple OI - Top-Level VI.vi" there is a missing sub-VI named "TestStand - Set TestStand Application Window.vi".
(3,187 Views)
Hi Legal,
You should find the file here:-
C:\..\TestStand 3.0\API\LabVIEW\7.0\_TSUISupport.llb
Hope this helps,
Nick
(3,187 Views)
Nick:
Thank you. I found it there. But, when I loaded from the directory, I got a message saying that this sub VI is supposed to be loaded from a different directory. I wonder if this is because I installed TS3.0 before LV7.0. Regardless, program runs fine. The message is as follows:
Virtual Instrument
- The subVI expected to be at "C:\Program Files\National Instruments\LabVIEW 7.0\vi.lib\AddOns\TestStand\_TSUISupport.llb\TestStand - Set TestStand Application Window.vi" was loaded from "C:\Program Files\National Instruments\TestStand 3.0\API\LabVIEW\7.0\_TSUISupport.llb\TestStand - Set TestStand Application Window.vi".
(3,187 Views)
