NI TestStand
Missing Lines in text Reports
I am trying to print a report that is saved as a text file from the TestStand Report Tab. When I print, several lines are missing from the report and the margins are incorrect. When I set the printer to not include margins, the left side and top of the report are cut off. I have opened the text file from an external viewer and I have printed with no problems.
Are there any known issues printing text files from the report tab? Is there a way to control how the report viewer prints text files?
Thank you,
Jose
(4,377 Views)
Hi Jose,
How were your printing the text file when you experienced this issue? If you set the printer to include the margis does it still miss the lines that are not being printed ?
I was also wondering, which version of TestStand are you using ?
Sil.VI
(4,231 Views)
Hi S.jimenez,
I was printing the text file using the Print Button in the Report Tab. If the printer is set to include margins it still misses 2 lines.
I am using TestStand 2014
Thank you,
Jose
(4,227 Views)
