NI TestStand
Missing "Step Result Property" when configure multiple numeric limit database statement
In the NI article "Creating a TestStand Database Schema from Scratch" (http://www.ni.com/white-paper/6484/en/), it mentioned option "Apply To: Step Result Property" for statement "MEAS_NUMERIC_LIMIT". But I could not find "Step Result Property" in TestStand 4.2.1 as shown below:
Is there a workaround for this issue?
(4,124 Views)
The reference to "Step Result Property" in the article should have been "Property Result".
Scott Richardson
https://testeract.com
(4,115 Views)
Scott, thanks for clarifying the correct item to use for logging the results of multiple numeric limit test. So I assume "Step Result" is for single entry, and "Property Result" for multiple entries in the database.
Cheers
(4,103 Views)
Step Result is for operating on the step result itself if the required criteria is met, so this can occurs only once per step result. Property Result is evaluated on all subproperties of the step result and is processed if the required criteria is met, so this could occur more than once per step result.
Scott Richardson
(4,091 Views)
