NI TestStand
Modify UUT container?
How can I modify UUT container which is under ModelData.TestSockets[index].UUT. Need to add more variables to the UUT container.
If I rt click ans say view>Type Definition on the UUT container, TS returns error - "One or more errors have occured. Please save your work adn restart the application".
TIA.
CLD
(3,920 Views)
Are you able to view Custom Data Types by going to View » Types? I was able to go to the definition without any problems.
Rohama K.
(3,896 Views)
yes I can go to Types.
From the batch model I select the UUT container and go to View>TypeDef (image BatchModel_Step1.jpg)
Then on the type def selecting and rt clicking the UUT container always show the Insert Field as grayed out (image AddToUUTContainer_Step2.jpg)
So I can never add any varaible to UUT container?
If I repeat the procedure then TestStand displays the error and it then has to be relaunched.
Using TS4.1.
CLD
(3,892 Views)
Rohama,
Looks like I am missing the UUT container.
Just checked on another PC and when I click on the UUT container (as shown in image AddToUUTContainer_Step2.jpg) anad select view>>Type def then it takes to the UUT container. Whereas on my PC when I rt click and select to view >type def on UUT container I get the error "One or more errors have occured. Please save toy work and restart the application."
Any idea how to get the UUT container back?
Thanks!
CLD
(3,885 Views)
I'm not sure what you mean by missing. I would check to make sure your BatchModel.seq isn't a read-only file. Go to the file itself, right click and go to Properties. Make sure the box next to Read-only isn't selected.
Rohama K.
(3,881 Views)
