NI TestStand
Modify XML Report
I am working with TestStand 3.1. For the report generation I am using the horizontal.xls stylesheet. But when using this stylesheet, all steps of the test sequence are displayed in the report, including the "Done" steps, e.g. the flow control.
It would be fine if only the "Passed" and "Failed" steps are displayed. Unfortunately there is no possibility to modify the "result filtering expressions". This is only possible if you are using the html report format.
Now my question: Is there any possibility to realise a xml report format, which only shows the "passed" and "failed" steps?
Thanks for your help
Daniel
(3,168 Views)
Hi
You will need to filter out the results from the resultList before you generate the XML report.
Here is a web link which shows you how it can be done.
Hope it helps
Regards
Anand Jain
"How Do I Filter Results in a TestStand XML Report?"
http://digital.ni.com/public.nsf/websearch/93aa5cf5380f8d5986256f050059a440
(3,148 Views)
