NI TestStand
Modify report header
   After reading few threads, I am able to modify "reportgen_txt.seq" which is present in "C:\Program Files\National Instruments\TestStand 4.2\Components\Models\TestStandModels". The following statement added in main module of "reportgen_txt.seq" and saved.
Locals.Header += Str(ResStr("MODEL", "RPT_HEADER_SEQUENCE_FILE_VERSION_NUMBER"), "%-30s") + Parameters.VersionNumber.SequenceFileVersionNumeber + "\n"
 I have created a new sequence file and insert one statement and just executed.When I see report file, the header looks like below
String not found in the language resource files
UUT Report
Station ID:                   WHOAMI
Serial Number:                NONE
Date:                         Friday, July 31, 2009
Time:                         11:42:16 PM
Operator:                     krishna
Number of Results:            1
UUT Result:                   Passed
I feel that string ""RPT_HEADER_SEQUENCE_FILE_VERSION_NUMBER"" needs to be added some where..But I dont know where I need to add.Help me in this.
My report header should look like below
UUT Report
SequenceFileVersion:    0.0.1.0
Station ID:                   WHOAMI
Serial Number:                NONE
Time:                         11:42:16 PM
Operator:                     krishna
UUT Result:                   Passed
Let me know what are the changes I need to do to acheive above format.
krishna
(3,350 Views)
Above question udate:
I found the solution.
I need to modify  Modelsstrings.ini. Below is the step i added after "UUT Report" in Modelstrings.ini
RPT_HEADER_TITLE = "UUT Report"
RPT_HEADER_SEQUENCE_FILE_VERSION_NUMBER = "SequenceFileVersion: "
When I execute a sequence file I am able to see the below format.
UUT Report
Station ID:                   WHOAMI
Serial Number:                NONE
Time:                         11:52:41 PM
Operator:                     krishna
UUT Result:                   Passed
Now my question is how to add sequence file version number ?
(3,348 Views)
