NI TestStand
Modify to-call sequence name in pre-step?
Hi, I have the following problem: I have customized the "Call Sequence" step type, creating a custom step type that calls a sequence dynamically. The name of the sequence to call is represented by a step variable, which is edited in an edit substep.
This works fine.
Now I wanted to modify that step variable in a pre-step substep and found out, that obviously the step module is already "preloaded" (the to-call sequence name is evaluated) before the pre-step is executed. This results in a runtime error, something like "sequence not found".
What can I do?
Martin
Message 1 of 1
(3,008 Views)
