NI TestStand
MultiWindow Operator Interface - Modify Execution Window Title
I am using the multiwindow operator interface obtained from:  http://zone.ni.com/devzone/cda/epd/p/id/6372
I would like to modify the title displayed in the execution windows to show the test socket number and UUT serial number as I am running 6 UUTs in the batch process model and it is not obvious from the current title which execution window belongs to which UUT.  The current title shows:  TestStand Operator Interface - [Test UUTs -- Test Socket Entry Point - SequenceName.seq[#]]
where # varies from 3 to 8.
Does anyone have any suggestions on how to do this?
Thanks!
Note that I am using the multiwindow user interface instead of the TestStand Operator interfaces because I want to have tiled execution windows displayed for each of the test sockets, and the TestStand OIs do not do this.
(3,624 Views)
Accepted by topic author ShawTestEng
Hi George Mah,
To Change the Operator interface you will need to change the source code, that is written in C#. To change it, open the solution in Visual Studio and open the MainForm.cs and follow the instructions on the following picture:
When you double click that "UIMessageEvent" you will be taken to the code for it. In the code you will have to add a new case to handle the changes you would like to make. Here is the code that you can use:
case UIMessageCodes.UIMsg_ModelState_Identified: // This message fires after the serial numbers are entered
                    foreach (Execution value in axApplicationMgr.Executions) // This allows for every socket to be updated
                        if (value.ForegroundThread.GetSequenceContext(0, out frameId).Root.AsPropertyObject().Exists("Parameters.TestSocket.UUT.SerialNumber",0)) // Checkto see if the serial number exists
                        FindForm(value).Text = "Index Number: " + value.ForegroundThread.GetSequenceContext(0, out frameId).AsPropertyObject().GetValNumber("RunState.TestSockets.myIndex", 0).ToString() + "      Serial Number: " + value.ForegroundThread.GetSequenceContext(0, out frameId).AsPropertyObject().GetValString("Runstate.root.Parameters.TestSocket.UUT.SerialNumber", 0); // Here are the paths through the teststand API to get to the information.
                    break;
This should take care of it. I hope that this helps.
Perry S.
(3,597 Views)
Hi Perry,
I added the code you provided and rebuilt the solution successfully, but upon execution, there are no apparent changes visible.
I also noted that (on both the original as well as the new executable) if I hover the mouse over the bottom left corner of the execution window status bar (next to the green circle icon) then I can see the UUT socket number and serial number.  This would work for me if I could get the info to be displayed always instead of just when the mouseover event occurs.
Thanks for your assistance.
(3,594 Views)
Hi Perry,
I reviewed the code you provided and noticed that when I cut and pasted it into my solution, some "?" had somehow materialized in the code.  I removed them and rebuilt the solution and it now works as desired.  Thanks for the support!
George
(3,582 Views)
