NI TestStand
Multiple numeric - comment for each measurement?
How do I add a unique report comment to an individual measurement within a multiple numeric step?  I know can use Step.Result.ReportText to add a comment for the whole multiple numeric step but how do I add unique comments to the individual measurements.  I am using TestStand 2.0
(3,213 Views)
Not sure about version 2.0, but in more recent versions of TestStand you can give each measurement a unique name at edittime that can be pretty much whatever you want it to be. I don't think there is any straightforward way to add reporttext to it at runtime. You could just specify in your reporttext which measurement you are referring to.
Hope his helps,
-Doug
(3,186 Views)
There isn't individual ReportText. But you could create a custom step type which includes a report text for each. But I think this well also involve modifying the report gen sequence files to handle this item.
Regards
Ray Farmer
Regards
Ray Farmer
(3,168 Views)
