NI TestStand
MyDaq using Teststand example
Hi I hope you're all well,I was looking for a bit of assistance, i've been doing the labview core 1 and 2 and the first teststand course and the  labview programming is coming on with a myDaq i've been using for various applications. What i was wondering was if anyone had any basic teststand programs for using a myDaq that i could download to try out and have a go using teststand with the myDaq. its just to get an idea how  the myDaq would be setup on teststand and get a basic a voltage type test to try out.
any help or assistance would be appreciated
thanks
(1,581 Views)
TestStand doesn't directly use DAQmx, instead, it will be used through one of the supported ADE, like LabVIEW.
If you already know how to use a LabVIEW VI with TestStand, just code your DAQmx calls within LabVIEW, that's it.
Santhosh
Soliton Technologies
(1,551 Views)
Thanks Santhosh for the reply, i had hoped i could have used the myDaq to setup a bench test. Would the Daqmx be put in the setuparea or the step area ?
thanks
(1,521 Views)
