NI TestStand
MySQL engine (MyISAM or InnoDB) to be used with NI TestStand
MySQL includes two engines : MyISAM and InnoDB.
Which is the best engine to be used behind NI TestStand when logging a large amount of data and expecting best performances ?
Any feed-back is welcome.
Jean-Louis SCHRICKE
CTA - Certified TestStand Architect (2008 - 2022)
CTD - Certified TestStand Developer (2004 & 2007)
CLD - Certified LabVIEW Developer (2003 & 2005)
(3,174 Views)
Thank you for posting your question on National Instruments' forums.
I guess you are French but for the sake of the other users of this forum, I will answer in English (although some of the documents below are in French).
There are a number of differences between these two engines and this issue has been discussed on the net many times.
Basically, the engine you should use depends of the database connection you are making.
I would say that InnoDB will give you better performances when transferring a large amount of data. A benchmark made by the people of mysqlperformanceblog.com, a MySQL tuning and optimization site highlights that InnoDB showed that InnoDB exhibits better performances that MyISAM (see http://tag1consulting.com/MySQL_Engines_MyISAM_vs_InnoDB for more information).
However, InnoDB is more complicated to use and requires more memory space to be use adequately than MyISAM. The data files are also a bit larger when using InnoDB.
Therefore, I would say that if you are interested only on performances, you should use InnoDB. If you are seeking an easy to use engine, you should probably use MyISAM instead.
Here are some other links containing interesting information about InnoDB and MyISAM (in French).
http://www.journaldunet.com/developpeur/tutoriel/out/040511-sql-types-stockage-myisam-innodb.shtml
http://www.tux-planet.fr/mysql-les-principales-differences-entre-myisam-et-innodb/
I hope the above information will help you.
Guillaume H.
National Instruments France
(3,153 Views)
