NI TestStand
Mysterious Entry Points
In <TestStand>\Components\Icons\NI_UIControls I found icons for subsequences.
There is SeqNorml.ico for Normal subsequences, SeqCalbk.ico for Model Callbacks, SeqReserved.ico for Engine Callbacks, SeqExePt.ico for Execution Entry Points and SeqCfgPt.ico for Configuration Entry Points.
There are also SeqCvtPt.ico, SeqDebugPt.ico and SeqEdtPt.ico, which are, based on the Pt suffix, some kind of Entry Points.
Does anyone know what are those mysterious Entry Points?
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(2,474 Views)
Hi Michal,
I took a look into this, and it seems these are not used by current versions of TestStand. I am not familiar with very old versions of TestStand, but I think they might have been used by TestStand in a version that predates 4.0. Since we are not sure if someone has a system out there that still uses these icons, we haven't removed them from newer versions.
Good find....
Cheers,
Ryan Curtis
Product Support Engineer
Automated Test Software R&D
(2,004 Views)
