NI TestStand
[NEED HELP]The connection between a bool button and a bus signal.
I'm not sure what would Veristand do if I connect a boolean button to a outputting bus signal.
Will the bus signal be 0xFF or 0X01 when button is true ?
I know the best solution is to try it.  But there is not a PXI machine this moment at my hand.
Message 1 of 1
(2,091 Views)
