NI TestStand
.NET API for SearchDirectories.cfg
Is there a .NET API available to interact with the SearchDirectories.cfg?  For example, is there a way to serialize/deserialize the XML to/from objects to use in code?
I know you can get the directories from the engine's SearchDirectories property, but I would like to get the info for a specific file path.
(1,366 Views)
Why don't you just read it as text/XML file?
(1,179 Views)
That is the approach I was taking, but didn't know if there is an API already available with more details/support.  Didn't want to reinvent the wheel.
(1,171 Views)
