01-14-2011 05:08 PM
We recently purchased a new testing equipment from Nexjen. The URL for the equipment is <http://www.nexjen.com/Home/NexjenVISNRFID/tabid/206/Default.aspx>. The problem is that when I ever I want to save the measured responses it saves it in a .iqx file. I was wondering if you guys know how to convert that file into text file with the correct values in it. I attahed a sample file with this message. thank you in advance for your help.
01-16-2011 08:59 PM
How is this related to TestStand? Have you asked the vendor? They are the only ones that would know anything about this format.
01-17-2011 01:17 AM
Dennis is correct your first port of call should be with Nexjen, although its seems to be based on LabVIEW and TestStand, it seems to be highly customised.
Nexjen may already have something that meets your requirement.
