NI TestStand
NI COMPACT RIO DEVICE DRIVERS Silent Installation
I need to Install Silently the Ni Compact RIO Drivers  25.8 Suite, to a lot of computers.
I try the commande line : compactrio-device-drivers_25.8_suite_online.exe /q /AcceptLicenses yes /r:n /log C:\Temp\nidaqmx.log
But that doesn't work.
Do you have any idea ?
Thank you
(155 Views)
Actually, this is probably not the right forum to ask this question???
Nevertheless, can you specify "does not work"?
(135 Views)
Thanks , but what will be the right forum ?
Thaht doesn't work ,because , nothing happens at all.
(124 Views)
Actiually, since it's an installation issue, I'd recommend posting here https://forums.ni.com/t5/NI-Package-Manager-NIPM/bd-p/1023
The installer you are using is basically a wrapper around a NIPM installation. A quick search wouldn't show any results on how to use command line arguments regarding an installer like this. The command line arguments you are using actually used to work back in the day before NIPM
Have you tried
start /wait Install.exe --quiet --accept-eulas --prevent-reboot.
(102 Views)
