NI TestStand
NI Compact Rio Module Support
All,
  I am trying to determine what is the latest version of NI Compact Rio Module Support.  I can only find 17.1.  The problem is that when I try to load that it is saying that I have to install Compact Rio 17.0 or later and install LabVIEW 2017 before installing NI compact RIO module support 17.1.  I am running LabVIEW 2019.  I tried downloading LabVIEW 2017, but I have to buy it.  So if you know how I can get around this issue or what the latest version of module support is, I would greatly appreciate any help.
Thank you in advance.
(2,002 Views)
You should be able to download the newer versions of the cRIO driver here that includes the module support.
These questions also might be better served on the Real-Time Discussion forums and not in the TestStand forums in case you have any more questions!
Dane S.
Product Support Engineer
(1,963 Views)
