NI TestStand
NI_FTPFiles Operation: How to set FilesToFTP--->LocalPath in Pre-Expression?
Hi Guys,
I need to change LocalPath parameter in NI_FTPFiles, but I don't know how to write the correct expression.
I can set it like:
RunState.Sequence.Main["FTP Files"].FilesToFTP.ArrayElementPrototype.LocalPath = "c:\\myfolder\\newfile.txt"
But it is wrong.
Any one can help me? Thanks very much!
(3,094 Views)
Try using Step.FilesToFTP[0].LocalPath = "c:\\myfolder\\newfile.txt".  Instead of 0 you could use a numeric variable.
It's the proper way to use it in that step anyway.
BTW- The reason yours won't work is because FilesToFTP is an array and has to be indexed.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,077 Views)
Hi ~jiggawax~,
You are absolutely correct!
I take the index into parameters and works fine now.
Thanks very much for you help!
(3,056 Views)
