NI TestStand
NI MAX System Requirements and Installation Guide
Where can I find the system requirements (storage, ram, and other necessary details) and also an installation guide on NI MAX?
(881 Views)
Can you specify the background of your question?
Usually MAX  just runs  ... and installation is done automatically
(878 Views)
I actually don't directly work with this software so I'm not sure how to go about gathering info related to system requirements, which I need it to purchase a pc with those specs. I need to just test the installation on that pc and check if all the features are working fine on new pc specs.
(861 Views)
Thanks for the additional information.
Generally speaking, I haven't come across any up to date PC, which has problems running MAX (x86, x64, have't worked on ARM so far)
Since MAX usually comes with the Instrument Drivers, you might want to use those requirements for orientation like https://www.ni.com/pdf/manuals/ni-daqmx-2023-q1.html?srsltid=AfmBOopin94rtDIrm7LH7eFYA9dFx6JmXCfQ29E...
If you need more specific inforamtion, I recommend posting to a more appropriate forum like
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/bd-p/140
or
https://forums.ni.com/t5/Multifunction-DAQ/bd-p/250
(858 Views)
