NI TestStand
NI Requirements Gateway 2012 and Excel
Just a short question. I have an excel file wich is saved as .xml. I would like to use it in NI-RG 2012.
Only .xls and .xlsx were supported.
I there a posibility to use my .xml file
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,049 Views)
Hi Juergen,
Unfortunately there is no built-in type to parse .xml excel files, only the .xls and .xlsx files are supported, as you mentioned.  However, you could create a custom XML type to read this data.  To do so, open the Types tab in the configuration window, and click the New XML Type button at the bottom left.
Refer to the Types topic in the Requirements Gateway help for more info on creating and customizing types.
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,034 Views)
