NI TestStand
NI Test Stand v3.5 Call Executable step response
I am currently updating a NI test stand 3.5 application, the code is based on Labview 8.2.1; this application has only runtime installed due to is a user interface application. The requirement is to communicate the code to a cmd execution file, this code returns a text as a pass-fail communication test. I configure the call executable step with no issue nevertheless I cannot rescue the text from the cmd to continue with the test. ¿Where can I find the resulting text from the cmd? Thank you for your quick answer.
Message 1 of 1
(4,060 Views)
