NI TestStand
NI TestStand 2012 support for Python step types
Hi ,
I am using NI Teststand 2012 for most of my automation scripting. I want to use a python script to be called. Does NI Teststand 2012 support python step types?
Kiran
(2,524 Views)
The Python Step Types support TestStand 2014 and later. In 2012, you should still be able to call python scripts using the command line. You can find an example here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3k0CAA&l=en-US
-Trent
https://www.linkedin.com/in/trentweaver
(2,507 Views)
Would I be able to pass parameters in that case? Actually I wanted to make a user interface using the steps.
Kiran
(2,499 Views)
The ability to pass parameters is limited and is covered in that tutorial
(2,493 Views)
