NI TestStand
NI TestStand Reporting string
Hi, How can i include "Ω " in "step.Name" function of an step in expressions .
(3,298 Views)
As far as I know, TestStand does not support Unicode... I'd recommend just to substitute that symbol simply to "Ohm" text (if it's about resistance measurements). In many-many cases, unicode symbols are not critical for applications... If this one case is important, try then to contact NI techsupport - maybe now they have some workaround...
(3,274 Views)
Hi kosist90,
Thank you for your usefull response.
(3,262 Views)
