01-10-2018 09:01 PM
I am using TestStand 2016 and I am using the Deployment Utility.
I am receiving a build error -19000 with the following details:
LabVIEW is using a file with the same name as one of the destination files. National Instruments recommends that you close LabVIEW before you build a deployment. Open VI Reference in AB_Source_VI.lvclass:Open_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_API Do Two Step Build.vi:4020001->AB_API Build.vi:4700001->NI_AB_API_Build.lvclass:Build.vi->NI_AB_API_SDIST.lvclass:Build.vi->SDBuildClass_2013.lvclass:Build.vi->Build Distribution - TestStand.vi->Build VI Distribution 2010 - TestStand.vi->Build VI Distribution 2010 - TestStand.vi.ProxyCaller VI Path: C:\Program Files (x86)\National Instruments\LabVIEW 2015\vi.lib\XNodeSupport\FindTerm.vi
Can you let me know what I am doing wrong to resolve this? I appreciate the help.
01-11-2018 12:15 PM
Hello ArmandoP :
Have you checked the following forum?
https://forums.ni.com/t5/NI-TestStand/TestStand-Deployment-Error-19000/td-p/3180879
01-11-2018 12:38 PM
Yes I looked at this forum. The originator's issue of error 19000 has different details compared to the error I'm getting after I looked at his log.txt file. I think error 19000 is generic error code that build utility generates.
01-11-2018 01:59 PM
Here are the steps I would follow if I were in your shoes:
Unload all modules from TestStand and close out LabVIEW dev environment. (Maybe even restart everything and don't load anything in TestStand or LabVIEW before trying to rebuild)
Try to build.
Slowly remove VIs until the build error goes away to determine the culprit.
One thing is that this could occur when you have two VIs named the same thing in your VI hierarchies.
01-15-2018 09:04 AM - edited 01-15-2018 09:09 AM
Hi Armando,
Could you post the log file from build?
