NI TestStand
NI Teststand 2017 trace.WriteLine
Hello all,
I'm using teststand 2017 32 bit and we create DLL's using the trace.writeline command to give info to the outside world.
When running the DLL using console (visual studio console proj) we get the info in e.g. debugview.
When we run the exact DLL using teststand, we don't see anything.
mark that using teststand 2014 we see the trace.writeline info.
Could someone please tell us how to obtain the trace.writeline info back in teststand 2017?
brgds
JCR
(3,477 Views)
Dear Jeroen,
I tried your findings ... and indeed i see the same issue...
(3,452 Views)
Hi Jeroen,
Thank you for your post.
Please can you tell me how this is created? Also, can you share the source and code?
What other software (and versions) have you got installed (including .NET, LabVIEW, Windows)?
Kind regards,
YD
(3,393 Views)
Sure,
we do e.g. :
DLL:
        public string Init(string ResourceName)
            string read = "";
            try
                Trace.WriteLine("-- FSC3 -- Enter Init Function");
                mbSession = (MessageBasedSession)rmSession.Open(ResourceName);
                read = Query("*IDN?\n");
                write("*RST");
            catch (Exception Ex)
                Trace.WriteLine(string.Format("{0} {1}", "Error when executing Init commands with device : ", Ex.ToString()));
                read = "Error when executing commands with device";
            Trace.WriteLine("-- FSC3 -- Exit Init Function");
            return read;
And in the test program we do:
            FSxxSpectrumAnalyzer FSC3 = new FSxxSpectrumAnalyzer();
            string IDN = FSC3.Init("TCPIP0::192.168.0.100::INSTR");
then we see it the output:
When we perform this function from the teststand:
we don't see anything in debugview.
setup : Win 10 enterprise 64 bit, teststand 2017 32 bit. VISA, spectrum IVI (FSL3), visual studio 2017 pro, latest .net
when I try this out on a win 7 PC 64 bit, I get the trace in debugview.
(3,383 Views)
Hi Jeroen,
Thanks for sending that across.
I have a few questions:
  • When trying this code in TestStand 2014, has it been tried in both Windows 7 and Windows 10 computers? Does it work in both PCs when using this version? This will help me understand which TestStand versions have been used on which operating systems.
  • Please can you send a MAX report of both machines
Creating a MAX Technical Report to Document Configuration Information - National Instruments
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9mPSAS
  • Have you tried to run the code as Administrator? Windows 10 will often block commands if not run as admin
  • Try to disable the antivirus and run the code. The anti-virus can block commands.
  • You may have missing drivers on the new system.
Hope this helps
(3,376 Views)
Hi Jeroen,
Have you had a chance to try the steps I suggested in my last post?
Kind regards
(3,325 Views)
seqedit reroutes the tracing:
seqedit.exe.config contains:
<trace autoflush="true" indentsize="1">
        <listeners>
          <add name="TextListener"  type="System.Diagnostics.TextWriterTraceListener" initializeData="C:\Applprog\log\tstrace.log" />
          <remove name="Default" />
        </listeners>
      </trace>
delete it from seqedit.exe.config and the tracing goes back to e.g. debugview
(3,165 Views)
