NI TestStand
NI Teststand ATML Toolkit for 2014
I downloaded the toolkit to try off the web but the toolkit is not compatible wioth Teststand 2014.  What is the solution for TestStand 2014 for an ATML toolkit or am I missing something? Smiley Indifferent
(5,435 Views)
Hi id,
Thank you for inquiring. You are correct that the TestStand ATML Toolkit 2013 is not compatible with TestStand 2014. Unfortunately, we do not currently have an ATML toolkit that is compatible with TestStand 2014. If you would like to use the toolkit, you will need TestStand 2013.
Brittany V
(5,401 Views)
Are you intending on upgrading the toolkit sometime soon to work with Teststand 2014 or are you discontinuing it for some reason?
(5,367 Views)
That's a good question; I do not know our plans for the toolkit. Let me look into the situation, and I will give you an update once I know more.
(5,342 Views)
id-
We have published a KnowledgeBase article that addresses NI TestStand ATML Toolkit support for TestStand 2014.
-Jeff
(5,220 Views)
