NI TestStand
NI Teststand Model Plugin
I'm still a newbie with Teststand and I want to create a Model Plugin to process some results for our company.
We have purchased the 2019 version of Teststand.
My client uses versions 2016/2012 and I am wondering if my 2019 model plugin can work on 2016/2012 ?
How can I work to create stuff on a 2019 version for older version if this is not possible?
Thank you very much and sorry for the basic question.
I haven't found any kind of question here so maybe it is just me that is not enough experienced on that product.
Thank you
(2,313 Views)
Accepted by topic author ebonneau9
So I'm not sure of specifically what has changed over the years.  You'd have to dig through the What's New documents for each version.  However, you should just be able to back save your sequence file to previous versions of TestStand and make sure they are in the proper location for that version of TestStand so that it recognizes them as plugins.  Also, my guess is that datatypes and possibly plugin entry points have changed between versions.  You would have to massage them a little bit to make them work if that's the case.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,255 Views)
