NI TestStand
NI test stand video tutorials
hi
 i am beginner of NI test stand, i need some videos related to NI test stand and other PDF files.could any one help me to out
(4,081 Views)
If you are familiar with ActiveX and are used to OOD, self training on TestStand can be a good approach. However, i do recommend (esp. if you are not familiar with ActiveX and OOD) you to attend at least the first TestStand training from NI.
If self paced training is what you want to follow, please read through the TestStand documentation which is installed with NI TestStand on your computer. Also load and walk through the examples in TestStand (as long as they apply to your use-case).
I have not checked for videos or specifically newcomer material. If you have SSP along your TestStand license, you might want to check if training is available on demand.
Norbert
Norbert
Expert: Geometry
(4,073 Views)
thank you for your guidance
Regards
Raj kumar S
(4,068 Views)
Hi Norbert,
i am still learning, as well!
Please would you explain "OOD".
or is just that: https://de.wikipedia.org/wiki/OOD
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,063 Views)
OOD = Object Oriented Design. This is what *should* (has to) lead the way to OOP (Object Oriented Programming).
Norbert
Norbert
Expert: Geometry
(4,045 Views)
