NI TestStand
Need to customize the xml teststand report to output only one table for all the sequence steps
I want to customize the xml Teststand report to output only one table for all the sequence steps, instead of creating separate tables for 'main sequence' and 'subsequence'.
Kindly help me.
Arvinth
(3,005 Views)
You will need to customize horizontal.xsl stylesheet and  reportgen_xml.seq located under
C:\Program Files\National Instruments\TestStand <ver>\Components\Models\TestStandModels\StyleSheets and
C:\Program Files\National Instruments\TestStand <ver>\Components\Models\TestStandModels respectively.
Make a backup of the stylesheet and sequence so that the original is still available.
CLD
(2,991 Views)
