NI TestStand
Need to insert so information about a unit in a access database, however final information isn't gotten unless unit passes test.
I am new at teststand, here's what I got.  I created a test sequence, that basically records the serial number, test the board, then calculate a MAC_Adress for this unit if it passes all the other test.  the calculation of a MAC adress is done in a sub sequence file.  This test works.  Now this information needs to be logged to a data base.  what I did was created a copy of one of the existing schemas in test stand, and modified the tables I needed.  I am having two problems, one I get an error if I try to log additional results, (database options),  Two, i can not firgure out how to place the MAC_Adrress in the UUT_Result table.  Table format is currently:
ID  STATION_ID   UUT_SERIAL_NUMBER   USER_LOGIN_NAME  START  EXECUTION_TIME  UUT_STATUS  ERROR_CODE  UUT_ERROR_MESSAGE
Like to add UUT_MAC_ADDRESS between the serial number and login name, which i created the column, however having problems getting that p[arameter in that field.
(3,006 Views)
Hallawt,
What kind of error are you getting when trying to log additional results. Do you have the additional tables defined in your access db? The  ID  STATION_ID   UUT_SERIAL_NUMBER   USER_LOGIN_NAME  START  EXECUTION_TIME  UUT_STATUS  ERROR_CODE  UUT_ERROR_MESSAGE are all parts of the header, you can modify this by going into the process model. There are two excelent resources on how to do this for html: http://digital.ni.com/public.nsf/allkb/F8243CE782AFF42086256E62006B3FC1 and for XML: http://zone.ni.com/devzone/cda/epd/p/id/4759.
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(2,985 Views)
