NI TestStand
Negate 2D Array
Hi All,
I have a 2D array with numbers in (Locals.numbers) that are passsed into a Labview VI to control a motor (the Labview VI attached is just a demo to try and solve the problem). This works fine as it is but I would like to send the motor in the opposite direction and thought I could use the same Array (Locals.numbers) but negate it. I can fix this in Labview (numbers Array * -1) but can't seem to find the answer in TestStand. Can this be done?
(4,465 Views)
There are similar threads http://forums.ni.com/t5/NI-TestStand/Math-operations-on-array-in-TestStand/td-p/2738060 which have no solution.
So the awnser is most problably it's not suported in teststand as a simple math operaion. Ofcourse you code do some jugeling in a parameterized subsequnce but that is not what youare looking for if I'm correct.
Would be nice hough if it did exist.
(4,442 Views)
OK Thanks. Looks like I'll have to create another array but with minus numbers
(4,437 Views)
Or as you stated make a LabVIEW VI which inverts the array. That would prevent making chnages in two places if (or most probably when 🙂 ) you get new requirments.
(4,435 Views)
